Anyone know where I can find info on the conversion from the Weber carb to the Dellorto carb for My Paso?
Anyone know where I can find the Dellorto carb itself?
Is there much difference between the two?
Dellorto Carbs?
mika750paso
There is a complete dellorto kit available in Malossi catalogue,
go to this site http://www.malossi.com
Mika
Mika
Frankie
Weber vs Dell'Orto
Hi, I kept the original Weber but placing the suggested pressure regulator between pump and carburetor.
I used a typical second-hand Alfa Romeo Giulia fuel filter (glass) with pressure regulation bolt on top (found for free!).
The result is incredible!!
No more fuel leakages, no more engine stops!!!
Very responsive throttle etc.
The typical problems of this bike desappeared.
You all have to try it before spend big amount of money to replace carburetors!!
Frankie
Frankie
