Finally put all of the pieces (well almost) back together on the Paso today and took her out for the first time. SHe runs sooooo good. The idle issue is almost gone. I'm going to have to pull the carbs off again to see what can be done. Maybe some Mikunis will do the trick.
Note to self: Install cam covers BEFORE fitting all parts of frame together.
Like I said, MOST of the parts are back on. I'm going out for another ride right NOW!
She's on the road again!
DucSoup
Re: She's on the road again!
Doh! I hate when I do things like that. (And I do it all the time)
Congratulations on riding again!
- jcslocum
Ride update:
My daughter and I did a DESMO ride today 2 up on the old girl. 300 miles today at elevated speeds and she's running just FINE. The idle "hang-up" at 3oooRPM is really a problem over the long ride today and needs to be fixed ASAP. Overall I'm thrilled to have the Paso back on the road!
The engine was out due to the output shaft bearing going BOOM and the cases making a big CRACK, then the chain went grrrr-grrrr, wacka-wacka, SQEEEEEEEEK, bang(again)...
You get the idea. It was an ugly mess. A little bit of ebay, some gaskets and elbow grease and all is well again.
- jcslocum
No. I'm oldfashioned and cheap. The problems are in the fuelling. The Dellorto's are finicky and the paso badywork just makes them a bitch to work on. I guess you can add lazy to the above description!DuC-MaN wrote:Do you use those Iridium NGK sparkplugs? On my '94 Supersport it was an improvement on running idle and low revs!
- DuC-MaN
I reckonize that description! :funny:jcslocum wrote:No. I'm oldfashioned and cheap. The problems are in the fuelling. The Dellorto's are finicky and the paso badywork just makes them a bitch to work on. I guess you can add lazy to the above description!DuC-MaN wrote:Do you use those Iridium NGK sparkplugs? On my '94 Supersport it was an improvement on running idle and low revs!
I only checked the one sparkplug on my 907, it's a Champion and they will do for the moment.... but with those Iridium plugs (i had on my SS), no choking is necessary, and only one short push on the starterbutton is needed...
| '92 907 I.E. | '88 750 Paso under construction |
