906 Starter motor
ducatipete
906 Starter motor
Need new brushes for my 906 starter motor, its a denso model, is the starter the same as fitted on 907, ie can I fit the kawasaki zx7 brushes as listed on 907 forum??? plus the small carbon bush that supports the armature is worn and needs replacing, is this available too???
- ducapaso
Brushes for ducatis pantah and later models are available in any ducati dealer, in kit with the entire iron support, but I can't understand what you mean with "carbon bush" (I'm italian... :toofar: ) If you make a search in the posts, you'll find also the suggestions for a good "do it yourself"
Have a nice work,
Nicola
Have a nice work,
Nicola
ducatipete
ducatipete
