907 brakes
tewsy
907 brakes
g-day 907 owners,can anyone tell me how much protrusion from calipers should front pistons be on front brakes.
- Finnpaso
- year: 0
Do You mean, "how far out" can those pistons come FROM calipers(brake sylinders)????? Or did You maen disck measurements, or what?
907IE -91 red/metal grey
907IE -91 red
907IE -91 red
tewsy
- Finnpaso
- year: 0
There are not any specs about, "how far those pistons can come", if enough far, piston pops away from cylinder. You have one "groove" in middle of pad(disc side), so You can see from that groove, what is limit of pad! But seems, that U have to pull out all pistons and make cleaning job to Your sylinders and pistons to work, like should. How much U know about that job??? If not so much, let it to someone, who really knows, what need to do. propably have to find also new seals to calipers and surely need to know, how to get air away from system after cleaning EVERYTHING.... Anyway its not so wise to open totally caliper sides from each others. All MUST be clean, before rebuild pistons to cylinders. Seems, that only one pair of pistons are working normally and some "shit" is causing thiskind problems.... All this is only quessing, cause i havent seen closely Your systems...
907IE -91 red
907IE -91 red
- Finnpaso
- year: 0
Yes, that can be problem. I taught, that SURELY he use normal rotors, which have right offset.... Remembering, that all that time Ducatis had same offset, also many later modells, like 851/888, SS and Monsters...
907IE -91 red
907IE -91 red
tewsy
- Finnpaso
- year: 0
Little strange, if ONLY "left" seems to be out of measurements???
Normally there is not ANY shim plates in front axle...
Can You take some close fotos??? My mail: finnpaso@gmail.com can load fotos. If someone need those from me, i can resend easily, but then need address surely...
Btw, are rotors original???? I mean designed to 907IE ....
907IE -91 red
907IE -91 red
tewsy
